Switch from $15 to $25 and up
ValeryD1
Question for PM experts.
What will I get as a result, after switching from $15 to $25 plan or up to $39. What will remain with my rewards and in general something will remain, given that these are not new poinScreenshot_20230720-074015.pngts, but the old system of rewards.
@ValeryD1  You will keep those old rewards I can confirm . I just made this switch myself and kept my rewards . Check it out
@ValeryD1
You can freely change plan and it wont' affect your current rewards, also confirmed by Community Manager here:
https://productioncommunity.publicmobile.ca/t5/Announcements/FAQ-amp-Troubleshooting/td-p/986594
Will I be moved to the new rewards program if I change my plan?
Changing your plan won’t automatically transfer you to our new Public Points rewards program. If you’re currently on our legacy rewards program, you will continue to stay on it. However, we encourage you to explore Public Points, as it opens up even more opportunities for savings.
CharlieWhisky
You get to keep all your rewards 😀
HALIMACS
@ValeryD1
So long as you do not switch to public points, you will retain all your typical renewal Rewards when switching plans.
Just make sure to not switch to public points. Because once you do, there's no going back.
