a month ago
a month ago
Which goes back to my first statement of an updated device list. I also tested other carriers Bell also confirmed that the device was compatible. I only mentioned Telus as Public mobile uses Telus.
a month ago
@ClarkWyatt wrote:I did that and it stated not compatible however Telus says that it is compatible on their network so I believe it's Public Mobile that has not approved the device on their networks.
There are also mistakes in the Telus list. As with any large database, there will be some errors.
a month ago
a month ago - last edited a month ago
Check the IMEI of the Fig Flip 2 to see if it is VoLTE.
https://www.publicmobile.ca/en/get-help/articles/volte
It might be compatible but it will work on 1900Mhz 3G if the frequency is in your area.
a month ago
Probably won't be much changed in a couple months when the final switch is pulled. As far as my understanding there is a slight difference between the devices Telus supports and the ones Public supports even though they use the same network.
