12-04-2022 11:11 AM
12-04-2022 11:30 AM
Depending how agents are busy, usually it is 15-120min.
12-04-2022 11:13 AM
Usually a few hours. Sometimes 1-2 days (rare though)
12-04-2022 11:12 AM
@dianneplaza , the response time is dependent on ticket load. Generally you could see a response in your inbox within an hour.
12-04-2022 11:12 AM - edited 12-04-2022 11:13 AM
30 - 120 minutes typically.
If longer than 3 hours, try again.
