SUPPORT TICKET
dianneplaza
How do i check on the status of a support ticket.
7 REPLIES 7
@dianneplaza
that's unfortunate... I typically make it a standard process to tell the customers I refer about the ins and outs of PM. it's not really a plug and play company...
dianneplaza
What send box? Are u referring to where u send post?
walker1
@dianneplaza
Try using a computer or laptop instead or connect your phone to a WiFi connection.
Just type CS_Agent into the send to box .
Then put your message into the message box .
dianneplaza
How do i send a private message. i recently joined PM and its 5 days i cant use my phone. This sucks and i am regretting my decision to move to PM.
walker1
@dianneplaza
You can try sending a private message to CS_Agent and reference your existing ticket number, while you wait for their reply.
dianneplaza
Meanwhile I have to go without the use of my phone
walker1
@dianneplaza
There's no way to do that. You just got to wait for their reply.
