Subscriptions
09-27-2024 11:17 AM
I have just found out that my existing phone number will not be accepted at public mobile. The message actually says the number is "invalid". I have paid $49.72 for one month, a SIM card and taxes. How do I get a refund?
Payment
09-27-2024 02:30 PM
any chance you are trying to port from Koodo Prepaid service? if you are, then support can help you to complete the transfer
or the. error coild also indicate you submitted a port request already
So, message support and ask
09-27-2024 02:13 PM
@Solanaboat, the only way to reach a support agent is by opening a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
It might take an hour or so for them to get back to you depending on how busy they are so just keep checking your inbox for messages, the top right corner should have an envelope icon where you can find your messages
09-27-2024 02:12 PM - edited 09-27-2024 02:12 PM
hi @Solanaboat what error you got? invalid number?
you can submit ticket to agent by using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
09-27-2024 02:09 PM
I can't seem to get to customer support for a refund. How do I do this??
09-27-2024 11:24 AM
HI @Solanaboat
please check again for phone number eligibility here (It is a Koodo site, but Koodo and PM use the same Telus system)
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
if it really shows not eligible to port, you can ask PM support agent to arrange refund since your account has not been fully activated yet
09-27-2024 11:21 AM
send direct private message to support .
