01-05-2024 08:49 AM
My subscription plan is $24/month with 4GB data at 4G speed (90-day subscription plan), does it mean I will receive 12GB data at the beginning of my subscription? Also, in my plan's offer details, it says <⁺This plan is for Quebec residents only and intended for use in Quebec.> I don't understand why is it only for Quebec residents, can you guys please explain it for me?
01-05-2024 09:20 AM - edited 01-05-2024 09:24 AM
@Jay45 For now it slated to end Jan 8 . But yes the third month free mean just that you get the third month free after the second month but you will NOT get 12GB upfront for use over 90 day you will get 4GB every 30 day for $24 . The post you marked a solution is incorrect. This 4GB for $24 is a 30 day plan ONLY
adding you can keep the 4GB for $24 30 day plan for as long as you like unless you decide to change plan or leave PM
01-05-2024 09:17 AM
01-05-2024 08:53 AM - edited 01-05-2024 09:00 AM
@Jay45 The 4GB $24 plan is just 30 day plan but if there was. 90 version of it then yes it would mean you get 12GB up front paying $72 upfront to use over 90 days
add @Jay45 there is only one 90 day plan available right now and the 4GB for $24 is not it’s 30 day plan . Here’s a plan that offer 30 day or 90 day
01-05-2024 08:51 AM - edited 01-05-2024 10:00 AM
yes, one will receive three times the data allotment indicated for a 30 day period at the start of the 90 day cycle.
EDIT @Jay45 … to be precise, check the plan details to see if it displays this for eligibility of a 90 day plan:
don’t be caught up on the Quebec only offering – Public Mobile seems to have had this communication issue with prior offerings and so long as all services work, you’re good to go 🙂
