03-06-2023 11:02 PM
Hi there,
I noticed today that I was not able to make or receive phone calls (just was getting a beeping sound). I investigated and saw that my account had expired today (?). So I added $40 worth of funds to my account, and now my account says active. However, my phone is still not able to make or receive calls. I am stumped as to why it had expired (usually it just charges my account automatically each month to renew). And also why my service is not returning. Help.
01-05-2024 09:13 AM
Can't make or receive calls
01-05-2024 09:13 AM
Sign up to a us roaming plan but I can't make or receive phone calls
03-07-2023 06:58 AM
Perhaps you all are affected by this: https://productioncommunity.publicmobile.ca/t5/Announcements/Resolved-Service-Impacts/td-p/955119
Can you try your SIM into another phone? If calls still don't work Turn off VoLTE if you have a VoLTE enabled phone.
If turning off your phone for a few minutes, then restarting it doesn't help, connect with CSA by methods provided above.
03-07-2023 01:01 AM
Me too. So maddening.
03-07-2023 12:26 AM
the same thing is happening to me,
03-06-2023 11:05 PM
did you try reboot your phone?
there has been issue with voice and PM supposed to have fixed it, maybe you are still impated.
Open ticket with PM support so they can check
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
