Subscription change
Yasmaee
Hello everyone, I am trying to change my subscription from the 34$ to the 29$ plan at my next billing date. I know it is not a big change but sometimes just a little helps..... anyhow, my total amount due now is 0$ but my transactions keep been declined ? The card registered in my account is actif and regardless of the insuffisant amount available to clear the fill subscription free; the due now amount is 0$ ..... why does it not allowing me to succeed the plan changes if the cost is 0$ .... im sure I got that amount in there... can someone help?
Are you saying that it is not allow you to make the plan change or not make a payment (or both)?  When scheduling a plan change, no payment is required. When requesting an immediate plan change, that's the only time that the Self Serve system will require a payment to made at the same time as requesting the change.
@Yasmaee
Are you changing the plan on the PM website or on the PM app?
Try refreshing your browser if you are on the website by clicking on the circular arrow. The estimated amount due should show as $29 plus taxes.
Phil_Adelphus
@Yasmaee  Which $29 plan are you going for?  There is one on the Shop page that is for new activations only or do you still see the $29 for 10GB available in your account?  Have you tried buying with the app and having location services turned on?
slusagm
it is likely just because of the payment systme glitch and nothig to do with plan change or not
you can make it happen quicker by buying voucher and load the voucher using *611.   Best to buy the voucher from London Drug or Shoppers
