Subscription Usage doesn't match Usage History
umnikke8
I'm seeing issues with my usage reports. I've made 2 long calls that show in my usage history but aren't reflected in my minutes used summary. Meanwhile data used summary is way higher than normal and what is showing in usage history for data is not adding up anywhere near.
Are VoLTE calls getting counted against data and not minutes?
14 REPLIES 14
umnikke8
@smurfit I did get an explanation from Public about this. The design of their system registers 100MB used whenever your phone is connected to the network. It still figures out how much is actually used and deducted from your quota, but always reports this extra 100MB buffer in the overview. I'm not sure why they chose this design as its confusing for users.
smurfit
I have noticed this problem as well. For the last few months, on the day my plan renews, it shows I have used 100mb. The phone shows zero or maybe a couple mb. Now I see today that they are slashing the rewards points again..
hi @umnikke8
so,  they acknowledged something wrong?
Ask them to give you a 1GB freebie for compensation
umnikke8
100MB of 250MB used from day 0. I checked with support last month, they said they were working on something, but still not working properly this month.
hi @umnikke8
there used to be couple Mb if buffer needed for data usage.  Many reported the 100Mb missing and it leads us to believe maybe the buffer usage is now 100Mb.   What plan do you have? It will be a tough lost if you only have 250Mb or 1Gb
I think you should check with support agent to confirm.
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
umnikke8
Into at least the 3rd month were extra data is reported in the Overview than actually used or reported in detailed history. Starts off immediately as soon as the next period commences.
Android or iPhone?? they both have build in tracker.
For iPhone,  you have to reset it every cycle
Android is better, just change the cycle date and it will show you the usage without the need to reset statistics
umnikke8
I don't have detailed tracking on the phone. But 2 months in a row, seemingly exactly 100MB extra recorded that isn't supported by the detailed usage history and completely different than all previous months. Not only that, but that 100MB has shown up on the first day of the billing period. It's not something I'm doing.
how about your phone, did you check if it reports any usage on the phone itself?
umnikke8
My new billing cycle just started today. I didn't use any data, none is showing in the detailed usage yet, however the overview already shows 100MB used. Must be a bug.
umnikke8
Yep I checked the cycle dates and compared within them.
For specifics I spent somewhere near 3 hours on hold over a couple calls in the past few days, all within current cycle, all outgoing calls. Those calls and their duration are shown in the usage history, but Minutes used: 2.
If I look through the data usage history it adds up somewhere around 3MB. But it reports 103MB used.
hi @umnikke8
you have the correct cycle start date ?  PM is on 30 days cycle and the cycle start date moves
and for minutes, while the voicemail minutes will show on the usage page, it does not count towards your minute bucket, could be the reason
or , you can ask support agent to check.   please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
umnikke8
Been more than 24h even 48h for some of it to settle out. Data usage is still way high, minutes used way low. Usage history doesn't show anywhere close to the amount of data it says has been used, while it shows the hour long phone calls spent on hold that aren't at all reflected in minutes used.
@umnikke8
The calling minutes are rounded up so 10 minutes 1 second will count as 11 minutes.
PM updates your usage twice a day…around noon and around midnight. So the usage will be updated to the correct amount.
Calls don’t count as data.
