Correct Plan Not Reflecting Under Account
GFR1
In Nov I changed my plan to the $35 50GB Can-US-Mexico plan to start with my next payment date of Dec 10th. On Dec 10th $35 + tax was withdrawn (instead of my old amount of $34). I was just checking my account and under Subscription it still reflects my old $34 Can-US plan although the Payment History screen reflects $35 for the Can-US- Mexico plan correctly. From the Subscription page I went and changed again to the $35 Mexico plan to be effective on the next payment date in Jan - but should I be contacting PM about this? Has this happened to anyone else?
GFR1
Thank you. Good to know. The incorrect subscription was showing on my phone, but I just checked on my iPad and it is correct. I will delete the app on my phone and reinstall which will clear the cache. Thanks for your help.
hi @GFR1
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
slusagm
PM site has poor cache control.  So, if you are using browser, use Incognito mode to login
if you are using PM app , logout completely, clear cache or even clear app data and relogin
with that, you will see the correct plan
