Subscription Switch Clarification $39/20gb
KIB
I'm currently on a $40/m / 15gb subscription. I also have many unused Add-ons collected for 4 years which are still unused completely. These include data / international minutes etc. My question is, If I switch to the currently available $39/20gb plan, will I lose these add-ons & rewards as well? I have not purchased any of these add-ons. TIA
Current Add-onsCurrent Add-onsDisclaimer when switchingDisclaimer when switchingCurrent RewardsCurrent Rewards
hairbag1
@KIB
all of those add-ons  and Rewards will stay intact. Just don't ever opt outta Rewards in favour of Points.
@KIB  You won’t loose a thing you get to keep it all I can confirm I just did this switch myself and kept my add ons  and rewards . Check it out
abtest
@KIB- you will not loose any of those add-ons if you change plans.
@KIB   yes you will be keeping your current add-ons and will stay on the current rewards system (legacy), you won't be force onto the new one with a plan change
The disclaimer is for those who have activation bonus, like 2GB for xx months or those promotion found under My Promotions section on My Account
So, no worry, make the plan change and enjoy
