Submit a ticket for porting problem
Icer
I activated my phone yesterday and did text YES when asked by Virgin if I wanted to port my number.  My eSim is toggled on and shows Public Mobile as my provider and shows my number that was to be ported to this phone.  When I try to submit a ticket it asks for the Sim number and says if using an eSim to type "N/A" but the input field will only accept numeric input.  The submit button at the bottom is greyed out, I assume because it says that all fields must be answered to submit a ticket.
My phone works for calls and data but if I try phoning my number from another phone I get a recording that it is no longer in service.
Is there some way to submit a porting ticket, ie: some number that I can enter into Sim number field?
nktheone
Please message me the number too.. I have the same issue can't enter N/A in the sim number field
Icer
Called the number (twice) and the last person said that her info show that the port was completed successfully.  I am still unable to dial in from another phone - get the recording - but she was able to give me a sim number to use so I could submit a ticket.  We will see how that goes
Icer
Thank you
Dunkman
@Icer
Yes, it looks like the your port is stuck.  There is actually the phone number for the Telus porting team.  I will private message you that number.  Only used for porting issues.
