Step 6 of 6: Activate - 'Subscription Not Activated
MiningCoffee
My subscription wasn't activated. Any suggestions?
Thanks
MiningCoffee
thanks!
@MiningCoffee  Support usually reply with in the hour sometimes longer . Just keep an eye on your community in box for their response . Or you can use this link to the community inbox
MiningCoffee
yes i'm using the app. re-downloading didn't work. i sent a message off. how long does it usually take to hear back?
@MiningCoffee  Are you using the app to activate and not the website ? All a activations the app . Maybe try uninstalling the app and re instal it . See if that helps . If not submit ticket with support
send a  private message   To CS_Agents
