Full Access Authentication Code Being Sent to the Wrong Phone Number
Salam1
Hi everyone, just posting here to see if anyone is still dealing with the same problem as me.
My PM service is working, however, I have still been unable to activate my account via the app or website, due to the authentication code being sent to a temporary # that I guess was created during the porting process. I was communicating with a CS agent, however I haven't received any update for a week. The last update was that the security team was working on this, and they even told me at one point it was fixed, when in reality, the issue persists.
This is really strange as to why they can't just update the phone number. Is there something else happening that is not being communicated to me?
I don't expect anyone here to solve my problem, but any bit of awarness or escalation on the PM support side would be appreciated.
Thank you and take care.
Salam1
The issue is now resolved.
@Salam1  Well that’s all you can do , so. Just keep an eye on your community inbox for their reply , or you can use this link to the community in box also
Salam1
@Handy1 Thanks, but I have done that and it just resets the timer on sending a new code to the same wrong phone number. Even multiple wrong attempts doesn't prompt it to let me send the code to my email.
I have also sent another message to the CS agent.
hairbag1
@Salam1
you should message CSA for update on your concern as its been too long...
@Salam1  Try tapping the option that says “didn’t get code “ then you might get option to send code to email instead . If same
 you can send a  private message   To CS_Agents
