10-30-2023
03:41 PM
10-31-2023
01:20 AM
computergeek541
Hello, I'm at step 6/6 where the activation failed without ESIM installed.
I was checking forum saying that there should be an activation email with ESIM QR code to scan but there isn't one and my credit card has been charged. Any help is appreciated.
10-30-2023 03:59 PM
thanks @hTideGnow , I have submitted a re-send request to PM support as there is no welcome email to begin with so I cannot install eSIM.
10-30-2023 03:44 PM
hi @coreslogic
you checked the Sim manager and sure the eSIM wasn't installed?
and yes, usually the QR code is on the Welcome Email, but if you don't have it, then you have to open ticket with PM support and ask them to resend
10-30-2023 03:43 PM - edited 10-30-2023 03:45 PM
@coreslogic wrote:Hello, I'm at step 6/6 where the activation failed without ESIM installed.
@coreslogic , did it ask you to install the eSIM, has it tried? Or there was no option at all to install it?
Edit: if it tried but just isn’t activating your service.
Please try these things below to see if any help. Others have experienced similar issue & sometimes these suggestions have worked!
(I had my data on plus my Wi-Fi was turned on & connected to my home internet to be sure I had all connections while doing this)
Reboot your phone.
In cellular settings make sure that “Turn On This Line “ (for iPhone ) is selected. (I am not positive where the setting is on a different phone to turn it on, possibly ‘Turn on your eSIM under Mobile Network’), reboot your phone. (You may need to reset network settings then reboot)
