Cannot connect to network
Hnausacaptive
Get SOS error message.  No connection.  Have installed new eSIM card.
Hnausacaptive
Thanks for your input.  I’ve tried all the tricks and am now in contact with a service agent.
slusagm
make sure the new esim is there and other (or old) sim or esim are removed or deleted
for the new esim, enable it.  Or Turn on this Line on iPhone and make sure it is Primary
then Reset Network Settings
eddieO
@Hnausacaptive have you tried restarting your phone? If so, go into your phone's cellular settings and check to make sure the eSIM is active, set to primary. Also, if you have any other eSIMs on your phone make sure they are not active. If you have a physical SIM card it would be best to remove it
If you are still having trouble you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
