09-25-2019 09:23 AM - edited 01-05-2022 07:16 AM
I am using a Huawei phone everything works fine but started few days ago text messages can't be sent or sent delyed more than two days.
Any idea?
09-25-2019 05:20 PM
Thank you!!
To add, I think this issue could be caused by a OS update which happened few days ago as well.
09-25-2019 01:57 PM
@Big8D Marking your own post as Solution is frowned upon, so I did it for you.
09-25-2019 12:30 PM
Thanks guys, I tried every thing thing but none of them works. So I hard reset the phone and it worked.
Thanks agian for all of you!
09-25-2019 11:56 AM
Did you recently travelled abroad and bought texting add on?
09-25-2019 11:39 AM - edited 09-25-2019 11:40 AM
@tsparkle21 wrote:Try rebooting:
- Open the Settings app.
- Navigate to Application Manager.
- Tap the All tab.
- Select your Messaging app.
- Then tap Force Stop
Or clear cache
Lastly, was there an O/S update? If so, you may have to install the latest version.
09-25-2019 11:34 AM
Try rebooting:
09-25-2019 09:34 AM
Maybe try the SIM card in another phone to make sure that it is a hardware issue, not a PM service issue.
Other things to try:
Try rebooting phone. Toggle airplane mode on. Wait a few minutes. Then toggle off. Network reset.
09-25-2019 09:33 AM
Pease contact moderators by clicking the question mark
09-25-2019 09:31 AM
everything works but sending message.
09-25-2019 09:30 AM
$15, text is unlimited.
09-25-2019 09:28 AM
Which plan are you on? If the $10 plan, maybe you ran out of the 50 texts? Does everything else work? talk? data?
09-25-2019 09:25 AM
It's stuck on "Sending..."
