09-13-2022 02:04 PM
Hi There all,
I'm new... just migrated over and signed up for 6gb at 4 g... just did a speed test at https://www.speedtest.net/ and it indicates I have 0.80Mbps at 81ms.... Does that seem slow?
09-14-2022 08:02 AM
That's not right.That's slow even by throttled data status. Log into your self-serve account and confirm your plan details just to ensure that you do have 4G service and not 3G service.
I suppose it's entirely possible that your data speed or your plan's data speed wasn't set up correctly or provisioned properly to your sim card. Contact customer support to open a tech team ticket for you so they can look into why your data is so slow.
Once your data speed has been corrected to approximately up to 100 Mbps and you're able to perform at least 3 speed test in a row with a consistent number that is to be expected from a 4G plan. Screenshot your data usage before and after you perform the tests. If you have proper 4G data speeds each test will use up to 400+ MB per test. Ask the CSA to reset your data counter with the data you used in the tests which could amount to more than 1+ GB.
09-13-2022 09:53 PM
@Lookingforadeal you have been activated for 4 days now?
If you have not restarted your phone since you activated (or in the last 24 hours), you will likely receive a better result if you power off your device completely, then start it up again.
09-13-2022 05:36 PM
Speed test eat your data like crazy. Do not be obsessed with speed. As long as it does what it is supposed to do for YOU, ignore any measurements...
09-13-2022 02:50 PM
09-13-2022 02:48 PM
Hi ... sorry for delay... had a work thing get in the way... I have an Iphone 8... it show LTE in the carrier bar...
09-13-2022 02:26 PM
Thanks... but it is only available in Alberta, BC and Que... I'm in Nova Scotia. I just retested on speed test and my second test was 0.34Mbps at 89ms
09-13-2022 02:24 PM
@Lookingforadeal wrote:I should have mentioned I'm also at about 93 hours or almost 4 days now as well..
That shouldn't make a difference becuase the the slower 3g plans are set to a maximum speed of 3Mbps. As of now, you're not achieving that. In addition, all new accounts are automatically set at the faster speed for the first 48 hours even if the slower speed plan is chosen.
09-13-2022 02:24 PM
HI @Lookingforadeal What kind of phone do you have? Make sure your network type is 4G or LTE or a choice that include 4G or LTE
If the settings is correct, then did you try your phone in another area? did you try your PM sim in another phone ?
You can also open ticket with PM CS agent to confirm the account was setup correctly on the system:
open a ticket with PM CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
09-13-2022 02:20 PM
09-13-2022 02:17 PM
I activated a new account... I was with Telus through a Sobeys Corporate program for approx 15-20 years.
09-13-2022 02:16 PM
I always use Telus speed test. choose the location nearest to you.
09-13-2022 02:11 PM
HI @Lookingforadeal did you just activate new account or you are existing PM users and change plan from 3G plan to 4G speed plan?
Usually with a speed change, it will take as many as 48 hours for the new speed to apply
Since you just change to 4G plan, wait 2 days, 48 hours, and try speed test again
