5G not working
timahdex
my internet connection is very slow or not working at all. I checked and confirmed that I am on 3G speed instead of 5G. I subscribed to 5G speed, why am I on 3G? Please upgrade my speed ASAP.
11 REPLIES 11
@timahdex wrote:
Thank you for your response.
I only see 3G and LTE option on my iphone 11
@timahdex , the iPhone 11 is not 5G compatible.  The best you can do is select LTE which is 4G.
hi @timahdex
sorry, iPhone 11 does not have 5G.
but you can still use 4G or LTE to get close to 5G speed
timahdex
@BKNS27 wrote:
My iPhone gives me an option for 4G, 5G and 5G Auto.
Does it give an option to select a different network for voice and select a different network for data? I don't believe that any phone gives that option.
@computergeek541
@BKNS27 wrote:
Is your cellular data & voice set on 5G in the phone setting?
There isn't any way to make a phone use one network type for voice and another network type for data.
@timahdex
will13am
@timahdex , all plans have access to the 5G network.  The plan type determines the speed cap on the plan, not the network access.  Having said that, your phone would only connect to the 5G network if there is 5G service in your local area and provided that your phone supports 5G.  As for data speeds, that is determined by local network traffic.
Yummy
Forget about xG speed. To many people hanging on internet tictok and other stuff so infrastructure cannot handle all that...
I experience slow speed too. WAY slower than my home internet.
hi @timahdex
do you see the phone connected to 3G or 4G or LTE or 5G?  it should show on the top of the screen
go to network mode and manually choose to change to 5G or change to 4G or LTE as well to try
