Something went wrong with activation
Vanessa11
I am at the final stage of activation, but it says something went wrong with activation. Asked CS_agent as advised, but no answers!!
Tried to get a ticket, but the page shows ‘blank’ with ‘done’ on the top right only.
How can I contact a representative to fix this?
Munchking
Hey there, could you specify what "final activation" stage you were in??? Are you in the part where it asked you to enter your account number from the previous carrier? And after you enter it, it doesn't go through when you click activate?
eddieO
@Vanessa11 did you try completing activation through the Public Mobile app installed on your phone? This is a required step that is often overlooked. If you did use the app then use the link provided by @Handy1 but please note it often takes an hour or 2 to hear back, sometimes longer depending on how busy they have been throughout the day
@Vanessa11  No worries use this link to contact support
send  a  private message   To CS_Agent
