4 hours ago
I would like to know how I can connect with a customer service agent. I couldn’t download the eSIM, and it showed a message asking me to contact an agent. However, I wasn’t able to get through when I tried.
Does anyone have any recommendations?
Thank you in advance!
4 hours ago
hi @Anjitha
sometimes you got the error because the eSIM already installed. Please check
fisrt, make sure your old physical sim card is removed , or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
On the same Sim card Manager, or Settings->Cellular screen, check if Public Mobile esim is there. If it is , make sure it is set with label: Primary and enabled (or Turn on this line is enabled), then Reboot your phone and Reset Network settings
if that does not help, ask support agent to check, submit ticket by direct message:
