07-29-2026 05:14 PM
I'm a new customer. visa, email, all the process questions answered. Filled everything out. Last step. "unable to activate". how do i fix his. Currently i cannot send or receive any calls. I need my phone for work. HELP!
07-29-2026 05:17 PM
hi @jon-
If you got the error ""SUBSCRIPTION NOT ACTIVATED" at step 6, Reboot your phone, re-login and the app will try to complete the activation
If same, then remove the old carrier sim card, or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Then put the PM sim card in the phone, or if eSIM, you should be good
Next, go to Sim Manager or Settings->Cellular and check if PM sim is showing there. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help. You can submit ticket by direct message:
07-29-2026 05:16 PM
Try reboot the phone and re-login the app and see if the app can complete the activation.
But if you still get the same error, you will have to ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
