activate sim card, provision error
Gibby3
I have a provision card error how do I connect to my SIM card
1 REPLY 1
@Gibby3  If it’s physical SIM card you have you can try putting it in another phone to force it to re provision itself if no luck you or eSIM you will need to get support to help
send  a  private message   To CS_Agent
