11-02-2022
03:54 PM
11-02-2022
04:10 PM
computergeek541
I setup my plan to change on renewal. It showed everything setup and ready to change on my plan screen. Today, upon renewal, it now shows my old plan still, and over 2GB data used and it's the morning of my renewal...not even possible to have used that much data(out of the old 5GB plan I had) in the time since I was connected to my homes wifi the while time! What is wrong with PUBLIC MOBILE THESE DAYS? THEIR WEBSITES BARELY WORKS FOR ME, EVER! AND HARDLEY EVER ON MOBILE DATA, AND THEN I HAVE TO CONSTANTLY RELIAD THE SAME PUBLIC MOBILE PAGES OVER AND OVER AGAIN AND WASTE EVEN MORE DATA? FIX THIS CRAP!
And then I can't even talk to a real person who has control over my account and stuff. To get this figured out I'm expected to talk to customers who cant tell me why something didnt work the way it said it was supposed to. LET ME TALK TO AN AGENT!
Service
11-03-2022 01:01 AM - edited 11-03-2022 01:02 AM
PM seriously needs to put some effort into fixing this cache issue on their "improved" website. The amount of CX issues they undoubtedly need to spend time on should be enough to justify spending some money on their website. This is a prime example of asthetics being prioritized over function. Sure it's pretty, but it's completely useless if it shows inaccurate information. Not to mention the spinning widgets are slow AF.
11-02-2022 04:24 PM
@dust2dust all good..
11-02-2022 04:21 PM
@Metal1967- I'm still not getting the faraday reference. I know what it is. I don't know what you mean in your context.
11-02-2022 04:17 PM
@dust2dust crazy.. they think we live in a faraday cage..😂😬
11-02-2022 04:11 PM - edited 11-02-2022 04:11 PM
It is utterly ridiculous. They blew the wad on this ridiculous update that seemed to have little to no testing and with that little to no corrections, rolling out this indeed janky website.
The little spinner refresh icons lower down are also very useful for updating the information. They otherwise completely lie saying it just updated.
11-02-2022 04:08 PM
Yes that worked. It is now showing the correct plan. Ridiculous that Public Mobile cannot have a website that functions like every other website out there...why does it have to be so janky? Anyways...thank you for the 8nfo and help. I will check the speed again in couple of days. And I'll remember to use a private mode for something that should work no matter what...stupid lazy webmasters be damned!
11-02-2022 04:07 PM
@Giggs wrote:LET ME TALK TO AN AGENT!
If you had paid attention when you signed up with PM you would know that there is NO live support at PM.
Account issues are handled by agent through personal mail and everything else by calm and unselfish customers through postings at Community.
11-02-2022 04:05 PM
@Giggs yes, Speed change takes up to 48 hours. So, it is good to test the speed after 2 days
So, did you login using Incognito mode or Private mode? Is it showing the correct plan and usage now?
Wait 2 days and you will be all good with your 4G speed plan 🙂
11-02-2022 04:03 PM
I'm also downloading via mobile network @1-3Mb/s. That does not match up even close to the 4G network...so I AM still on the 3G
11-02-2022 03:59 PM
@Giggs hi you are most likely seeing a cached version of your account try a differrent browser in private or incogninto mode then try to sign in again,that should clear things up
11-02-2022 03:58 PM
@Giggs , it is best to navigate the self serve account using incognito mode to avoid viewing a cached web page.
11-02-2022 03:57 PM
@Giggs could be just a cache issue
Please try to login again using Incognito Mode or try to login with another browser. With Incognito mode, you should be seeing the real usage
