07-05-2018 01:30 PM - edited 01-04-2022 06:23 PM
07-05-2018 02:59 PM
Does your phone work now and before? If it works ingore it, otherwise contact @CS_Agent with your account information is only solution.
07-05-2018 02:10 PM
unfortunately once the account goes into suspension, you required a mod to unlock the account. I wish PM could change this.
07-05-2018 01:53 PM
Is your phone working?
07-05-2018 01:52 PM
@yaloization, if you have topped up and are unable to restore the account to active status, I suggest contacting the moderator team to investigate and correct the situation. The moderator team can be reached via private message using this link. Refer to the following knowledge base link for information on contacting the moderator team.
07-05-2018 01:32 PM
Funds have been there for a day and mods have left me high and dry.
