12-01-2025
11:33 PM
12-02-2025
02:00 AM
computergeek541
I activated my eSIM and transferred a number from Telus.
I received a confirmation SMS from Telus asking to confirm I had initiated a transfer. I replied yes
I received a new confirmation SMS from PM that the transfer had been complete, and to please restart my phone.
on restarting my phone, service has not showed up in 2 hours. my account on PM website is just all zeros - see screenshot.
My Telus account shows a pro-rated credit indicating successful cancellation.
Please help. I'm stuck without a phone and have to go to work tomorrow.
12-01-2025 11:45 PM - edited 12-01-2025 11:45 PM
there is a chance that the Public Mobile esim is already installed and just not properly enabled
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually. If you cannot find it in Inbox of your email, check also the Spam box.
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM by private message CS Agent using this link:
**Monitor your Community inbox (envelope icon on the top right) after ticket submitted, CS Agent will reply to you there will reply to you there
