05-02-2023 05:18 PM
My plan DATA, voice and text are working intermittently from places to places. Switching networks but when you change city you have to set to something else. In the meantime you missed a lot of communications.
MAKE IT WORK PLEASE
05-02-2023 05:59 PM
Though you've been given suggestions for accessing services in the US (presuming you're either on the older plan which includes US service or you've purchased the correct Roaming add-on), if you still need customer support to assist, here's how:
05-02-2023 05:53 PM - edited 05-02-2023 05:54 PM
You are posting to a community board. We are all customers. You need to submit a ticket to reach a CS agent.
05-02-2023 05:29 PM
So you have the old $60 roaming plan from a few years ago?
Just keep the phone set to automatic networks. Set the mode to 4G/LTE not 5G or 3G. If you have the ability to change to 2G/GSM then that could be useful when needed.
05-02-2023 05:21 PM - edited 05-02-2023 05:23 PM
When you are in the US, you need to switch to the T-Mobile network manually on your phone.
You might also want to check the T-Mobile coverage in the area you are at.
05-02-2023 05:21 PM
@AndrerWere you able to connect to T-MOBILE?
For voice, PM has enabled VoLTE for many customers. Try to enable VoLTE on your phone and see if it works.
