No cellular data options for US roaming
Matt75
I assumed my US-Canada plan would allow my data to work in the US. Calls work, but no data/texts and there are no cellular data options to turn on roaming in the settings. What am I doing wrong here?
7 REPLIES 7
hi @Matt75 try Reset Network first
and if you have another phone, test the sim card there
if same , ask support agent to check you can  submit by direct message:
Matt75
Physical SIM here. I’ve done a reboot, but not reset networks.
@Matt75  Is your iOS up to date ? 18.1
hi @Matt75 eSIM or physical sim?
try reboot the phone and try Reset All Networks
Matt75
not sure why my cellular data options aren’t showing up???
@Matt75  It does , have you turned on data roaming in phone settings yet
hi @Matt75 what phone do you have?
make sure you enable mobile roaming data on your phone
Make sure you connect to T-Mobile, At&T or Verizon and use 4G or LTE instead of 5G
