02-04-2022
05:31 AM
02-04-2022
09:25 AM
Dunkman
I have registered my sim and selected a number, payment was successful. It's been over 12 hours and the sim is still not working, I have tried it in other devices and it still doesn't work. I've also put a friends functioning sim in my phone so I know it is an issue with the sim not the phone. Is it possible it may take up to 24 hours or something?
02-04-2022 10:59 AM
HI @braedenpicard Can you at least make outgoing calls? And is Mobile data working? if they both not work, I think there is a problem with provisioning your SIM card on the system. Please open a ticket with PM Support.
If you cannot login to My Account, then you will need to open ticket by direct message:
If you can login to My Account, please open via Chatbot as that is quicker:
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Whichever way you open ticket with , after ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
02-04-2022 10:52 AM
If you are not porting an old number and picked a new number.
Try powering off the phone then power the phone back on with the SIM in the phone.
02-04-2022 10:25 AM
As soon as you register and activate your SIM you should have service.
Maybe SIM has to be provisioned. Please contact agent through personal mail (if ticketing does not work very first time you try it) and ask them to investigate and assist.
Let us know what was the issue when it gets resolved, please!
02-04-2022 06:19 AM - edited 02-04-2022 06:21 AM
@braedenpicard wrote:I have registered my sim and selected a number, payment was successful. It's been over 12 hours and the sim is still not working, I have tried it in other devices and it still doesn't work. I've also put a friends functioning sim in my phone so I know it is an issue with the sim not the phone. Is it possible it may take up to 24 hours or something?
Did you activate with a new number or transfer one over?
If new, what happens when you call the number?
Ensure to reboot the phone with the SIM card inside, and try perform a reset of the network settings.
Still issues...then contact CSA.
Methods to contact Customer Support (CSA) found here: https://www.publicmobile.ca/en/bc/get-help/articles/contact-an-agent
EDIT, can you log into self serve and check your status? What does it say: https://selfserve.publicmobile.ca/
Anything when you call 611 with the sim card in the phone?
02-04-2022 05:43 AM - edited 02-04-2022 05:43 AM
No, it doesn't take 24 hours. Something went wrong. Open a ticket. Open the chatbot and ask to contact a CSA customer support agent.
