02-04-2022 10:35 AM
Hello, my friend wants to switch to PM with MOTO ONE VISION, but only model XT1970-1 & 3 on phone list. Is XT1970-2 also compatible with PM? Thanks.
02-04-2022 10:53 AM
Hi All, great support. I got the info. Thanks you all.
02-04-2022 10:43 AM
HI @gyw XT1970-2 is an American version it does look like it will work
Your friend already using the phone now? make sure the phone is unlocked
If buying new, make sure to buy from a trusted source
02-04-2022 10:40 AM
This model should work with Public mobile also.
Here are the specs:
https://www.phonemore.com/specs/motorola/one-vision/xt1970-2/
Primary 3G network | UMTS 850/900/1700/1900/2100 |
Primary 4G network | LTE Cat6 (Bands 1, 2, 3, 4, 5, 7, 8, 12, 17, 28, 66) |
https://www.gsmarena.com/motorola_one_vision-9647.php
Public Mobile uses the following frequency bands:
3G = 850 (5), 1900 (2)
4G = 850 (5), 1900 (2), 700 (12/13/17/29), 1700/2100 (4), 2600 (7), 1700/2100 (66)
02-04-2022 10:40 AM
As long as that phone supports and can handle PM's frequencies, you should be OK.
Ideally, if you can find a friend with PM service and try SIM in that phone to be 100% sure.
