07-15-2022
11:10 PM
07-16-2022
07:27 PM
Dunkman
07-16-2022 12:14 AM
If you received a welcome email from PM, your SIM card should be activated. Otherwise, you SIM card may not be activated.
07-15-2022 11:17 PM
Are you porting your old number to your PM account ?
07-15-2022 11:13 PM
do you port in
07-15-2022 11:12 PM
@jacobsnap does it show NO SIM ? No network? SIM not provisioned?
And it is not connecting to the network at all? Talk / Text / Data , none of them work?
it is possible a sim provisioning problem. just need to open ticket with PM Support and they can fix it from the back end
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
