01-13-2024
06:58 PM
01-14-2024
07:21 AM
computergeek541
So I just switched from samsung to apple, and when I take my sim card out of my samsung an put in into my iphone it says that the carrier is not supported, and I should either try again or contact the carrier. It still didn't work when I tried again, the phone itself is fully setup, and the chatbot was pretty useless, so I'm here now. What do I do? I can't even call public mobile for a new card, I don't know how I should get a new card that is compatible with an iphone. Help?
01-14-2024 07:11 AM
@Michael38 Before changing carriers, you didn't answer my question about the carrier lock in settings, which is what Apple says to check for the message you are getting. Best to do this first because otherwise you may have the same problem with another carrier also. My iPhone works just fine on Public Mobile.
01-13-2024 07:34 PM
@Michael38 If it's still not working, go to Settings - General - About - Carrier Lock, what does it say there? It shouldn't be locked if it was purchased in Canada but someone had one the other day that was.
01-13-2024 07:17 PM - edited 01-13-2024 07:18 PM
Hey @Michael38 Do as @HALIMACS suggests by resetting the networks. Just know if you have saved any WiFi log ins and passwords also including any bluetooth, you will lose that information and have to reset it all again. But when you do reset them, reboot the phone with the SIM in it.
If you're using iOS or iPadOS 15 or later, tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. If you're using iOS or iPadOS 14 or earlier, tap Settings > General > Reset > Reset Network Settings.
On a side note, you should update your iOS while you're at it. BTW, welcome to the Dark Side! 🙂
01-13-2024 07:03 PM
This phone is brand new, I just got it a few days ago, and set it up today
01-13-2024 07:01 PM - edited 01-13-2024 07:02 PM
Put the SIM card back in the iPhone, then reset network connections.
Is this a BRAND new iPhone or have you used it before with a mobile provider in Canada?
