Porting issue
12-20-2024
06:47 AM
12-20-2024
12:17 PM
computergeek541
I responded “yes” to my previous carrier text to proceed with porting. It has been over 12 hours now and still nothing has happened. I don’t believe the number has ported. Maybe it’s something I did
Joining Public
12-20-2024 08:07 AM
can you make outgoing calls and does data work? if they both work and just problem with incoming calls, then it is a stuck port. There is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
however, if there is no service at all, then it is a setup problem and you need to ask PM to help by message them here
12-20-2024 06:53 AM
@Rileymurfy44 When you say nothing has happened, do you mean your previous carrier's sim still works? If it doesn't have you inserted your Public Mobile sim and restarted the phone?
