07-10-2023 10:01 AM
Hi there,
I cannot find my sim card. So I decide to buy a new one to replace it. But I cannot log in my account because I cannot receive the confirmation code to the phone number. And I didnot registerter the trust device either.
How can I skip the procedure for the code?
Thanks!
07-10-2023 10:24 AM
07-10-2023 10:21 AM
@esjliv OP lost the sim, so, cannot receive text from Frogot password
07-10-2023 10:18 AM
07-10-2023 10:16 AM
@TPliu wrote:I used another account to log in. I have two phone numbers in public.
@TPliu - are you talking about logging into the Community (where you are now), OR logging into My Account? These are 2 different distinct areas of login and need to be set up or rather linked if they have not been before.
07-10-2023 10:11 AM
Yes, PM system is one email for one account. So, you must have a second email associated with this second line.
Please message support and ask them to lookup the email used for you
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
07-10-2023 10:11 AM - edited 07-10-2023 10:12 AM
@TPliu - was the sim card you lost activated that you paid for with a subscription / plan? Or did you lose a non-activated card?
If you didn't have a paid plan attached to this sim card than you have no My Account to get access to.
If this was a SIM Card with a subscription/plan attached, than try entering the code incorrectly a few times, that should also give you an email option.
Once logged into My Account:
See how to report lost / stolen: https://www.publicmobile.ca/en/on/get-help/articles/lost-or-stolen-phone
See "How To Change Your SIM Card" in this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/change-sim-number
If issues with your My Account, click here to request a SIM Swap with the Public Mobile Customer Support Agents (CSA): Submit ticket for a SIM SWAP
typo
07-10-2023 10:09 AM - edited 07-10-2023 10:12 AM
@TPliu But both phones lines have its own email
adding so long as you know the credentials for both accounts to verify you can log into ether account to contact support and fix the appropriate account that’s having issues
07-10-2023 10:08 AM
07-10-2023 10:05 AM
@TPliu Tap resend a few times you should get an option to send code to email instead . If all else fails please
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
