Sim activation and porting
Binmansoor
Hello my phone is no esim compatible so now figured  out that I require physical sim .which I finally got from Amazon. Now what. How do I go about setting it up
@Binmansoor
Did you already activated an eSIM plan for your phone? Or you didn’t yet?
hairbag1
@Binmansoor
you'll need the PM app to activate the new account. You'll be given direct in the process on how to port your number to your new PM account. Make sure to use a family or friends PM referral code for your $10 credit.
@Binmansoor  Use this direct link to contact support to SIM card swap the number for you if you had failed eSIM attempt setting account . If you haven’t sent up account before just download the PM app and creat account and activate the sim
send a  private message   To CS_Agents
HI @Binmansoor
just submit a ticket with CS agent and they can update the sim number for you and complete the activation for you
please submit a ticket with CS Agent here:
