01-07-2022 06:46 PM - last edited on 01-08-2022 09:36 AM by Dunkman
01-07-2022 10:37 PM
@DESTROYERtank wrote:I keep getting the message on my phone sign in to fido Network I would like that message no longer to be coming up on my phone anymore it's annoying me.
It could be an open wifi network that needs authentication to use the internet. Delete any wifi network named Fido and turn off open wifi network notification.
01-07-2022 07:38 PM
@DESTROYERtank - perform a reset of your device's network settings.
If still issues, check that the APN settings are correct for Public Mobile: https://www.publicmobile.ca/en/bc/get-help/articles?q=apn
01-07-2022 07:07 PM
Hi @DESTROYERtank Any chance to provide a screenshot? A picture tells 1000 words
01-07-2022 06:54 PM
Is your data otherwise working normally? (not wifi)
01-07-2022 06:49 PM - edited 01-07-2022 06:52 PM
if is real SMS from Fido you can contact to Fido to unsubscription your phone number from them system or maybe is it a scam then ignore and delete and block..
01-07-2022 06:47 PM
Sounds like it's coming from an app on your phone. You may try visiting a local phone repair shop to pinpoint the source and have it resolved.
Public Mobile does not provide phones, so they wouldn't be able to help with it.
