Sign-in verification text sent to old (first number); although it's been changed to new number
Waj
@CS_Agent
hello good people,
I am new customer of Public Mobile, barely a week or so.
here is the issue, I changed my First number that was assigned to this account to the new one that is easy to remember. today, i tried to log-in but the System sent the verification Text to first number instead of the new one. Therefore, I cannot sign-in using that method. I had the system sent verification code to registered email address. upon checking the profile, it does list the NEW (current) number. I signed out to test it again, but it keep sending Text to Older (first) number.
May you advise the solution to this conundrum please?
Phil_Adelphus
@Waj   As others have said, you need to log in to your PM account using the email option for the code and then go to the Eversafe profile and change the phone number there to the new one.  For some reason when you change PM phone number the Eversafe profile doesn't automatically update and keeps sending the code to the previous number even though the PM profile shows the new one.  This happened to me when I changed numbers.
Waj
Jesus!! it worked.  thanks.
Try checking if eversafe has your new phone number.
Go to account, overview then profile. Click manage Eversafe ID and check if the new number is there. If it is then I’m not sure how to help you but you could try speaking to a CS agent.
@Waj wrote:
I already mentioned that and used that to sign-in. I am concerned about why it is NOT sending it to current number ?  I need to rectify the issue where it SHOULD send the verification Text to current number.
@Waj , the ever-safe ID does not appear to track phone number changes in an account.  You will have to edit the number in the ever-safe ID database.  You can do this in your online account profile.
Waj
TheSterlinger
If you sign on using a compter it will give you an option to send the code to your email address provided on file.
