09-19-2019 02:57 PM - edited 01-05-2022 07:11 AM
Is there any way we can share our data with someone? If so, how do we go about doing this. I just never use all of my data up within the month.
02-26-2022 09:44 AM
@Aimie wrote:Is there any way we can share our data with someone? If so, how do we go about doing this. I just never use all of my data up within the month.
HI @Aimie Which plan do you have? If you don't use up all the data, maybe downgrade the plan?
Even you are on $25 plan, downgrade the plan only gives you 100 minutes of calling time and it might not be enough, you can add the $5 for 500 minus Canada wide talk add-on, that brings the monthly total to $20, still cheaper than $25. (and with the 500 minutes talk add-on, it is an add-on and it has no expiry and it will roll over to the next month. So, if you not used up 500 mins monthly, your overall monthly $$ could be even less than $20)
02-26-2022 08:58 AM
No, unfortunately no such thing. But you can share data with your family and friends by using hotspot while they are nearby. Hope this helps.
09-19-2019 11:06 PM
I think the best option is to get a lesser plan (unless you're alreay usting one of the cheapest ones and still not using up your data). Aside from that, start hotspotting to let others use your data!
09-19-2019 10:53 PM
If you are both close by......could make a hotspot.
09-19-2019 03:04 PM
@Aimie The only way to share your data is when the other party is in the same location. Just turn your device's hotspot on and aloow them to connect to your device.
09-19-2019 03:03 PM
Unfortunately, there are no family plans. You can only have one account, email, phone# per sim. There is a $15 plan with 250 MB and a $25 plan with 500 MB.
09-19-2019 02:58 PM
Sorry there is no way to share your data.
09-19-2019 02:57 PM
Sorry, no. It's one account per plan/add ons. There's no concept of a family share plan or anything.
