07-04-2021 03:10 AM - edited 01-06-2022 02:58 AM
Hi community,
I'm helping a friend set up his voicemail but there is no prompt for making a pin #. He's been a customer for a while but he has never used or checked his voicemail. I held and pressed 1 but can't find a menu for the pin #?
07-04-2021 03:58 AM - edited 07-04-2021 04:01 AM
07-04-2021 03:53 AM
Here's the voicemail menu....
07-04-2021 03:37 AM
Ok thank you that worked. How do I change a greeting? I tried to get greeting recorded but just got these two old drunk guys yammering in the background.
07-04-2021 03:22 AM
Ok I will help him do that and see what happens.
07-04-2021 03:16 AM
@carlaspapa wrote:I'm helping a friend set up his voicemail but there is no prompt for making a pin #. He's been a customer for a while but he has never used or checked his voicemail. I held and pressed 1 but can't find a menu for the pin #?
The voicemail password is chosen the first time the custoemr calls into it. When there's an issue with it, the voicemail password can be reset from the self serve account. After logging in there, click on Plans & Add-ons, and then on Reset Voicemail Password.
