05-11-2023 11:05 PM
Hi guys,
Can I transfer my public mobile phone number to an other company like under Rogers? But with the same phone number I currently have with public mobile, is that available?
05-12-2023 10:33 AM
Sure you can - and you can actually get a live Rogers agent to do this for you. Good luck.
05-12-2023 08:24 AM
Yes. Just make sure your PM account is still active during the process or you might lose your number.
05-11-2023 11:11 PM
@AkifYesil generally speaking, YES . But it is best to check with your new provider as while most nimbers can be ported, but not all.
To port out, you start the process from your new provider
But first, make sure your PM account is currently active and you can receive text without problem. Login to My Account and get the account number from Profile page
While you are at My account, you might want to also disable Pre-Authorized payment just in case.
Then activate your new line with your new provider and request to port a number. Provide them PM's account number as the porting information
this is critical: Then still have your PM sim card in the phone, wait for PM to send you a text to confirm your porting request. You need to reply YES within 90 mins
After you replied yes, you can put your new sim card in the phone and wait until you get incoming calls. Once you are getting incoming calls, porting is completed. Your PM account will also be closed at this stage (you will no longer be able to login to PM My Account after)
05-11-2023 11:10 PM
@AkifYesil Yes, you can definitely transfer or port out your current number to any provider. Please know that your PM account must be active and any remaining service will be forfeited if you port out your number. All you need to do is provide your PM number to Rogers for example to initiate the number transfer request.
Is there a reason you're looking to move your number to another provider?
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
