11-30-2024 09:27 AM
Recently subscribed via esim and after replying "yes" to the text received by my previous carrier, I have not had service for over 10 hours. Additionally, I cannot access my App as after logging in and verifying with 6 digit code, it just keeps refreshing the app login.
11-30-2024 11:58 AM
@Jonu Glad to hear you got it working.
11-30-2024 11:45 AM
As an update, i got it working through customer service. Apparently my number did port but was not assigned to my account. Hence the issues. CS tagged it on and a restart to my phone got it working.. Goodluck @10secdream
11-30-2024 11:00 AM
If you cannot get the Esim to work you may need a physical card to work, or below
Hi Community,
We're happy to share some news that aims to make your eSIM installation process smoother and easier. As of June 15, we've started including an eSIM QR code in our activation summary emails.
Why does this matter?
If you encounter any difficulties downloading your eSIM during activation in the app, you now have a quick and easy solution - the QR code provided in your email. To effectively use this feature, open the email on a different device so that you can scan the QR code with the phone you want to use for your Public Mobile service. This lets you download your eSIM directly, and once done, you can log back into the app as an existing user.
This enhancement is part of our ongoing commitment to streamline our services and provide you with the best possible experience.
Stay tuned for more updates,
The Public Mobile Team
11-30-2024 10:59 AM
OP and I have a similar issue and neither of us can login and therefore cannot start a support ticket. Currently waiting for CS Agent to respond to my message.
11-30-2024 10:55 AM
To erase your eSIM on your iPhone
Go to Settings.
Tap Cellular. Then:
If you have a single plan, tap Delete eSIM.
If you have multiple plans, tap the plan that you want to erase. Then tap Delete Plan.
If your carrier offers an app, that too can be used to enable an eSIM on an iPhone. Check with your carrier for further details.
11-30-2024 10:49 AM
Iphone, yes, i had a separate esim for Fido and through PM's activation, another esim was added for PM.. I changed my password and still can't log in.
11-30-2024 10:45 AM
Try changing your password if it allows you too, then try logging in again
11-30-2024 10:44 AM
What is the brand of your phone
11-30-2024 10:43 AM
Was the esim in your phone used for another provider before you came to PM
11-30-2024 10:41 AM
agreed.. experiencing same issue.
11-30-2024 10:40 AM
Yes to both and I know it works because I get the PM 2FA sent to text but other sms/calling services do not work. I also can't log into my account either.
11-30-2024 10:39 AM
Yes, I restarted my phone and yes, PM is at the top of my screen as the service provider. With the esim settings also say the provider is public mobile.
11-30-2024 10:38 AM
After you changed it to esim primary did you restart your phone and do you see PM located on your screen after you do it
11-30-2024 10:30 AM
Yes, I've turned off the Fido ESIM which makes the PM ESIM the only active one and I cannot get service still.
11-30-2024 10:27 AM
Did you shut off or remove the old sim card from fido once it was deactivated. If you used Esim you have to make Esim primary on your phone for PM to kick in
11-30-2024 10:17 AM
I also ported over from Fido last night. The port was complete and my Fido account was deactivated. Been waiting in limbo since yesterday and sent a message to CS Agent 9 hours ago.
11-30-2024 10:15 AM
I was previously with Fido through esim as well. The esim from fido is still on but no service which likely means it is porting but I starting the part at 5:30PM EST yesterday and still no service from PM.. I've restarted my phone multiple times.
11-30-2024 10:13 AM
@Jonu, @10secdream, have you tried restarting your phone? If you place your old SIM card back into your phone is it still working (calling in/out, text in/out, data)? If so, porting did your complete. It's possible that because the porting request came yesterday evening that it's taking much longer but it should definitely be working by now. If the restart does not start reach out to a support agent as it's now open for business hours so you should get a response within a few hours
11-30-2024 10:04 AM
hi @Jonu
just a bit more time. usual wait time is within 2 hours
11-30-2024 10:02 AM
customer support has not replied to my message in over 20 minutes..
11-30-2024 09:39 AM
you can message Customer Support for their assistance...use this link to start that process...
11-30-2024 09:29 AM
Also having the exact same issues.
