Service Unstable Since Nov 27
sbabcock
Since November 27, the service at my home has become virtually unusable - can;t make calls / dropped calls / blipping during calls
Have done the following :
Rebooted
Reset Network
Changed preferred network to 3G
Moved SIM to another phone - same issues
Purchased / installed / Activated new SIM - same issues
This looks like a Regional / Tower issue as it appears that my phone is fine in other locations
Steve
8 REPLIES 8
sbabcock
I had the network set to Auto and put is back to WCDMA (it was on LTS/WCDMA/GSM)
That may have helped a bit but can't be sure
This may be a service area issue - have posted a ticket
Kramy
Have you tried setting the preferred network to 4G/LTE? The Public Mobile "3G" is 4G/LTE throttled to 3-5 mbit on their end. You should be on an LTE connection in most areas for optimal connection strength. Right now in most communities, 4G beats 3G which beats 5G (since 5G is kinda spotty for now) which beats 2G. At some point 5G will improve and overtake 3G/4G.
Hi @sbabcock   Look like weak 3G in your area
open ticket with CS agent and report them the issue.  Hope they are already aware and are already working on a solution
To open ticket,
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
walker1
@sbabcock
You should probably contact a CSA agent from PM and have them reset your sim card and service. They can re provision your sim card again.
Either use the Chatbot Simon to get a service ticket or send a private message to CS_Agent
sbabcock
Service seems to be better elsewhere although most of the time I work from home so that's where I see the issue
gyw
if working good away your home, just report to CSA and let them check the R/S in your area
sbabcock
My service is intermittent - one minute I can make a call and the next minute I can't
Meow
Most likely something to do with cell tower in your area.
Do you get any service when you are out of your area?
Check here for outages:
https://istheservicedowncanada.com/status/telus/map
TELUS Service Status
