5 hours ago
Hello,
I can't send pictures by text message. Can someone please fix this or any suggestions. I was never able since I made the transfer from Koodo 7-8 years ago, same for my gf. Thx. Denis
3 hours ago
Thank you so much for your help I appreciate it.
3 hours ago
HI @Marija77
I think you should visit Apple store for in person help
3 hours ago
Did everything the checkmarek is there, send pic = Not Delivered.
3 hours ago
@Marija77 You can try to turn off iMessage and turn off face time . Then in settings > general scroll bottom off page in blue “shut down “ tap it wait couple mins and turn phone back on and turn on iMessage and face time . The check mark should be there for send and receive and test again
3 hours ago
I Can send to regular text msg to Android, anyone in MMS or iMessage. 1)In Message there is no send-receive. 2) You mean a ✔️ beside my phone# there is none. thx
4 hours ago
@Marija77 Are you able to send regular test messages to Android users (SMS)? Can you check in Settings - Messages - Send and Receive and make sure your phone number is checked? Presumably you have cellular data turned on for MMS picture messages (although iMessage works over wifi and you said that doesn't work either?)
4 hours ago
Can't send by iMessage and MMS is enabled, from the msg holding same "Not Delivered".
Any other suggestion. Someone at the stand long ago told me there was a problem with my Plans. She fixed it, it lasted 2 weeks and the problem came back ever since then. thank you so much
4 hours ago
HI @Marija77
can you send by iMessage? is that just MMS (pictures via Text) problem?
go to Settings and make sure Send as SMS is enabled
and you can also test that, on a picture text that you cannot send, click and hold until a menu pop up, select Resend as MMS
4 hours ago
I phone x. Got the latest update of IOS. Thx
4 hours ago
Yes, No iMessage.
4 hours ago
what make is your cellphone ?
4 hours ago - last edited 4 hours ago
