09-04-2020 05:51 PM - edited 01-05-2022 01:05 PM
Hello,
I selected the wrong add-on option. How can I cancel this add-on and select the right one?
Please advise
Thanks!
09-04-2020 06:44 PM
Thank you for your replies! I could create a ticket 🙂
09-04-2020 06:07 PM
I prefer using the private message option. Follow @gblackma advice but when sending an initial pm to the moderators for a service request add the topic in the subject line ( purchased wrong add on) and a detailed message outlining the issue. Always include the following:
Including as much info as possible reduces the need for back and forth messaging and often can lead to your issue being resolved before they reply to you or you respond. Be sure to ask for a review link once your interaction ends to give helpful feedback on the moderators customer service.
Keep an eye on the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a message from the moderators. Responding promptly to messages will speed up service times.
09-04-2020 05:56 PM
@Mel7 click on ? on bottom right of the page, follow the steps, and create a ticket with moderators. They may help you with this.
09-04-2020 05:56 PM
@Mel7 depost the additional funds for the right add on if required, contact the moderators, explain what happened and ask them to reverse the incorrect add on and to add the right one. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
09-04-2020 05:53 PM
Generally, you can't cancel an add-on and all sales are final. A moderator might make the adjustment for you, but they don't have to. Is the incorrect add-on for something that you would eventually use?
