02-19-2024 09:04 AM
When I try to make a local call it says I don't have US Roaming on my plan. I'm not in the US I'm in Canada and I've made these calls many times prior to yesterday.
Yesterday it also said I had no plan. My plan isn't up until March 4th.
Umidigi Bison X10, Ontario Canada
02-19-2024 11:41 PM
@Haymakerboy81 wrote:When I try to make a local call it says I don't have US Roaming on my plan. I'm not in the US I'm in Canada and I've made these calls many times prior to yesterday.
Based on your lcoation of Kawartha Lakes, there isn't any setting that you could change by mistake to cause this. This isn't a phone settings issue. it is a Public Mobile account issue. I've experienced it myself and it's something that technical support is able to fix.
02-19-2024 11:39 PM
@Grinch wrote:
@softech wrote:try to put a 1 in front of the 10 digits number.
if you have been valling using the 1 I'm front, try dropping it and just using the 10 digits only
Amd for network connection on your phone, instead of using automatic, please change to Manual selection and choose Public Mobile
Exactly….. @Haymakerboy81 you might be picking up a USA cell tower.
Someone in Kawartha Lakes couldn't possibly be picking up a US tower.
02-19-2024 12:49 PM
02-19-2024 09:20 AM
02-19-2024 09:17 AM
use this link to message Customer Support...
the little envelop icon on top right side of the page will be highlighted when they respond to you.
02-19-2024 09:11 AM
Did both. No change.
02-19-2024 09:08 AM
try going in to your phone settings to make sure Public Mobile is the preferred network.
Try restarting the phone.
02-19-2024 09:05 AM
Note: I'm in Kawarthas Lakes calling a local number.
