06-15-2019 12:47 PM - edited 01-05-2022 05:23 AM
Looking to use a Samsung A50 on Public Mobile but do not see it listed. Anyone know if it is compatible?
Phones
06-15-2019 08:42 PM
Public Mobile bands are:
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
- HSPA: 850 MHz, 1900 MHz (UMTS).
According to the Samsung A50 spec sheet, the Samsung A50 supports the following bands:
- 4G FDD LTE: B17(700), B5(850), B2(1900), B1(2100), B4(AWS), B66(AWS-3)
- 3G UMTS: B5(850), B2(1900)
In conclusion, the Samsung A50 SHOULD be compatible with Public Mobile.
06-15-2019 01:22 PM
Staples
06-15-2019 01:22 PM
@Mark25 wrote:Looking to use a Samsung A50 on Public Mobile but do not see it listed. Anyone know if it is compatible?
Koodo is offering Samsung A50 on $0 down and medium tab $360.
If it works with Koodo, it will work with PM.
06-15-2019 01:13 PM - edited 06-15-2019 01:18 PM
What's currently on gsmarena suggests voice should be fine but LTE could be dodgy depending on towers in your area.
Samsung ca would suggest that LTE is fine. So yeah...where'd you get it?
06-15-2019 12:51 PM
Check the specs of the phone.
Public Mobile uses the following frequency bands:
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
06-15-2019 12:50 PM
@Mark25The phone is really new.. you have to give lists some time to update.
06-15-2019 12:50 PM
06-15-2019 12:48 PM
@Mark25As long as you purchase the north american variant it should work.
