07-15-2025 12:13 PM
Why does my account say my SIM card is active but says SOS??? It’s been 3 days. No internet. No calls. I’m so frustrated I could cry. If I knew I couldn’t talk TO A LIVE PERSON I NEVER WOULD HAVE CHOSE PUBLIC MOBILE.
07-15-2025 01:01 PM
The customer is already in contact with an agent.
07-15-2025 12:55 PM
can you confirm if CS_agent's reply? OP mentioned he didn't see any message in his Community inbox
07-15-2025 12:38 PM
Thank you for the escalation!
07-15-2025 12:26 PM
in my invox
07-15-2025 12:26 PM
There’s not a single reply to me
07-15-2025 12:25 PM
hi @saraccha
did you check the community inbox? PM agent should have replied there
07-15-2025 12:23 PM
New activation. Already crying because why is this so hard?
07-15-2025 12:23 PM
Yes it says it’s active. Yes I reset my network settings and no I didn’t put it in another phone because most people don’t just have a second phone readily accessible. I’ve opened multiple tickets over the last 3 days and no response. I just want a live person to help me
07-15-2025 12:16 PM
can you login My Account? does it show account active?
did you try Reset Network Settings on your phone? and you tried your sim card on another phone?
if you can login My Account, then open ticket with PM and ask for help.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
07-15-2025 12:16 PM
hi @saraccha
new activation ? or it just stopped working?
no need to cry, PM support agent will help. You can submit ticket by direct message:
