a month ago
Hi I am not able to make phone calls or receive any up in the right corner says sos
a month ago
It sounds like your phone is not reading the SIM. Remove the SIM and clean the contacts with a microfibre cloth and install back to the phone then reboot the phone.
a month ago
@Jimmy65 wrote:Hi I am not able to make phone calls or receive any up in the right corner says sos
To add, check your account to see if you're paid up. Sometimes, even if there is a credit card on file, the system can error and not make the payment on your behalf and you may need to manually do it.
a month ago
hi @Jimmy65
Try Reboot phone and click Reset network settings
if you have a physical sim, test it on another phone
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
a month ago
Turn on Airplane Mode, wait a few minutes, then turn it off—restart your device—reset the network—try a different phone
