SMS picture messages not coming through
Pblack177
SMS picture messages are not appearing or coming through several hours later.
this happened when I switched plans from the $120 90 day play to the $40 3G plan.
has anyone on the 3G plan had this issue?
@Pblack177 iPhones usually don't need APN settings altered. Are you using iMessage? If yes, have you tried disabling that? If it still doesn't work, try reset network settings from Reset menu. Please know that this will wipe all known networks including all WiFi networks you were previously connected to.
@Pblack177
 check out your device  APN  and do rebooting
Pblack177
iPhone 11.
ive rebooted my phone. Data works fine. MMS come through sometimes 5 hours later. What are the APN settings ?
Pblack177
It’s on.
NDesai
@Pblack177 What phone do you have? Have you rebooted your phone and confirmed data service working properly? Can you send our MMS right away? There is a possibility you might need to try reset network settings or manually update APN settings.
Timer
@Pblack177
turn on your mobile data.
