12-02-2024 12:40 PM
I transferred my wireless number from Rogers to Public Mobile on Saturday. Received text message from Rogers to approve the transfer, replied "yes".
I can access data and make phone calls (and have set up voice mail), but I can't receive phone calls or text messages. I tried re-starting the phone, taking the sim card out and putting it back in again.
Advice would be appreciated, thanks in advance.
12-02-2024 02:07 PM
Thanks @hTideGnow I can make outbound calls but cannot receive inbound calls or text messages.
12-02-2024 01:59 PM
HI @alvinlee
if you can make outbound calls and just not receive inbounds, then yes, porting team can help and I will message you the number
but if you cannot even make outbound calls, that is not a porting issue, you need to open a proper ticket with PM support. you can submit ticket by direct message:
12-02-2024 01:58 PM
I am having the same issue. Transferred on friday. Can you please send me the contact as well?
12-02-2024 12:45 PM
HI @wavydave
can you make outbound calls? if you can make calls and just not receiving calls, it is a problem with porting
PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
